How to connect your audio receiver device to your Fios remote control using remote codes
Your Fios remote control and set-top box are programmed when you receive them. Once your set-top box and TV are connected, use your Fios remote to program it to your TV.
With your TV turned on, press:
- Menu > Customer Support > Top Support Tools > Program Fios Remote, press OK and follow the prompts on your TV screen
Note: DRC800 Fios remote must be programmed using the steps in the user guide. Use the same steps if you need to reprogram your remotes.
To buy a new remote, visit the Fios Equipment & Accessories Store
Audio receiver remote control codes
Find your audio receiver remote control code listed in alphabetical order by manufacturer below.
The following codes can only be used with the Phillips P144 and Motorola DRC800 remote controls.
A - C
Manufacturer Codes ADC
0558
Adcom
3725
Aiwa
0148, 0216, 1415, 1432, 1668, 3614, 3615, 3616, 3617, 3627, 3636, 3670, 3680, 3718
Alco
1417
Amphion Media Works
1590, 1642
AMW
1590, 1642
Anam
1101
Anthem
3757
Apex Digital
1457
Audiotronic
1216
Audiovox
1417, 3754
Bose
0666, 1256, 1280, 1960, 3741
Capetronic
0558
Carver
0216, 1216, 3636
Classic
3664
Coby
3751
D – I
Manufacturer Codes Denon
1387, 3602, 3633, 3662, 3663, 3676, 3681, 3682, 3691, 3694, 3700, 3702, 3703, 3704, 3709,
3721
Emerson
3603
Fisher
1828
GE
3635
Harman/Kardon
0137, 0216, 0918, 1331, 1333, 3626, 3636, 3699
Hitachi
1828
Integra
0162, 1325, 1347
J – N
Manufacturer Codes JBL
0137, 1333, 3626, 3752
JVC
1401, 1522, 3618, 3659, 3668, 3686, 3695, 3706, 3712, 3713, 3715, 3729, 3737, 3738
Kenwood
1340, 1596, 1597, 3619, 3646, 3649, 3656, 3658, 3675, 3688
KLH
1417, 1455
Koss
1393, 3749
Lexicon
3758
LG
1320
Linn
0216, 3636
Magnavox
0216, 0558, 1216, 1296, 1541, 3636
Marantz
0216, 1216, 1296, 1316, 3636, 3727
McIntosh
3759
Mitsubishi
1420, 3708
NAD
3637
Nakamichi
3638, 3639
O – R
Manufacturer Codes Onkyo
0162, 0869, 1325, 1347, 1558, 3628, 3650, 3653, 3660, 3666, 3669, 3687, 3693, 3697, 3705,
3707, 3710, 3711, 3719, 3753
Optimus
0558, 0697, 1050, 1101, 3634
Oritron
1393
Panasonic
1315, 1335, 1343, 1545, 1575, 1660, 1790, 1791, 3629, 3630, 3667, 3683, 3701, 3723, 3728, 3731,
3732, 3733, 3734, 3736, 3742, 3743, 3745, 3746, 3747, 3750
Philips
0216, 1216, 1293, 1296, 3636, 3698, 3749
Pioneer
0041, 0177, 0558, 0657, 1050, 1411, 3607, 3608, 3625, 3644, 3645, 3652, 3654, 3677,
3678, 3679, 3689, 3690, 3722, 3740
Polaroid
3605
Polk Audio
0216, 1316, 3726
Proscan
1281, 3635
RCA
0558, 1050, 1101, 1281, 1417, 1538, 3609, 3620, 3635, 3748
RCA & Dimensia
3610, 3611, 3612, 3613, 3635
Rio
1896
Rotel
3760
S – Z
Manufacturer Codes Samsung
1322, 1527, 3720, 3755
Sansui
0216, 3636
Sanyo
1496, 1828
Sherwood
1104, 3632, 3724
Sonic Blue
1896
Sony
1085, 1285, 1468, 1585, 1685, 1785, 1786, 1885, 3606, 3621, 3622, 3631, 3640, 3641, 3642, 3643,
3648, 3651, 3657, 3671, 3672, 3673, 3674, 3684, 3685, 3714, 3716, 3717, 3730, 3735, 3739, 3744
Soundesign
0697
Sunfire
1340
Teac
1101, 1417
Technics
1335, 1545, 3629, 3630, 3661, 3665, 3667
Thorens
1216
Venturer
1417
Wards
0041, 0216, 3625, 3636
Yamaha
0162, 0203, 1203, 1303, 1358, 1402, 3600, 3601, 3604, 3623, 3624, 3625, 3647, 3655,
3692, 3696, 3756
Zenith
1320
Remote Control User Guide
You can download your user guide below for additional information on your remote control. Select your user guide below:
Looking to program your remote control? Follow these steps.-
            1.Turn on the device you want to program your remote to
            2.Press and hold the appropriate device button and press OK
            3.Release both buttons and the device buttons will blink twice
            4.Enter the remote code for the device, the device button will blink three times.
            5.Point the remote at the device and press the Power button, and your device should turn off. This confirms it is programmed!
Need more support?
